When driving the other night my lights started flickering and started shaking a little bit when coming to a stop sign I pulled over an turned it off an when I did the car had died i had to wait a couple minutes before the trunk would open to get a get jump after I jumped it back to normal no shaking an drived good the next day now the cel turned on an feels like it misfires bad and the light are flickering again. I have a new battery and new spark plugs installed a couple months ago no problems until now. What should I start to look at
1989 W124 260E
I Would first check the belts just to see if it is possible to turn the alternator pully . But If that is ok and no play, Check the output from the alternator . Most every time this problem crops up ,, its due to the regulator brushes in the rear of the alternator .If battery runs down , due to faulty regulator the car will shut down to save the information in the computer .
No play in the belts I’m going to go the dealership In the morning and get a new voltage regular and will post back if it fixes or not
Changed the regulator but now my key won’t click in the ignition I been had to wiggle it around for it to work since I got the car but now the key does nothing in the ignition
Update car on the way to the dealer I’m lost asfar as the key unlocking the doors and doing nothin in the ignition
Had to get a new key made and turns out it wasn’t the voltage regular my engine ground wire was disconnected
