1 - 8 of 8 Posts
Mercedes CLK 230 K / Mercedes C 230k / Opel Vectra 2.2 dti Caravan
Hello.
I own a W639 from 2004 with 115 cdi engine.
I installed yesterday CC, but i don´t now how to work with the Star programme...
I just bust it one week ago and i am very imature on that...
Can you tell me all the steps?
Sorry for that..
We do not need any sensor, right? Like gas pedal or clutch?
Hello again..
I now that, thank you.
I might present my problem by the wrong way...
I have the star diagnosis at home, but just one week ago and i do not know how to work with it....so i need the steps of the star diagnosis..
sorry
Hi,
Instructions below ( You need Developer mode on star!)
Here is how to:
Add cruisecontrol / limiter to your Vito/Viano W639 it's configuration.
This should work for all W639 till AJ08
In Developer mode :(tested version 10-2008)
In engine control unit:
Entwicklungen (Development data) ->F3
Password : flexecu ->F3
Steuergerate - Anpassungen (Control unit adaption) ->F3
Steuergerate-Anpassungen (Variantencoderierung) ->F3
VCD_Transporter->F3
a Pop-up tells you : "Mindest eine Codiereinstellung ist ungultig" confirm -> OK
Here you will find the option settings
write down the line that is blue.
For example : NSG or NAG_Klima_Wasserstandschalter
Now we search for the string that contains the same options + Tempomat and Begrenzer
So that will look like : NSG or NAG_Tempomat_v-Begrenzer_Klima_Wasserstandschalter
Once you find it , click it and confirm with ->F3
"Soll die Codierung in Steuergerat ubertragen werden ?"->F3
JA or YES->F2 to proceed
Now we log out the engine ecu and go to the :
Instrument Cluster ( Kombi instrument) (Magnetti Marelli)
Variantencoderierung Algemeine Daten->F3
Scroll down untill you see "Limiter" set to Ja or Yes ->F3
F2 -> F1 -> F1
Ansteuerungen -> Gesamstliste aller Ansteuerungen ->
Scroll down untill you see the line : Steuergeraet Resetten (PowerON-Modus) (FN_Reset_SG_Power_ON)
Press F3 and confirm again with F3
Now you will see the "Kombiinstrument" reboots
Cruise control coding is added succesfully to your W639 now
(THANKS TO QRIUS on DK for this INFO!)
Mark
Discussion Starter · #6 ·
Hello.
Thank you , thank you, thank you.....
ML63 AMG & 2 350 SLK with AMG kit.
Hi,
Here is how to:
VCD_Transporter->F3
F2 -> F1 -> F1
Mark
Nice one, you can do mine!
Discussion Starter · #8 ·
Hello.
I cannot do it...
Where should i find the place to choose the cruise control/limiter.
In which unit can we find the place to enter and write the password?
Thanks...
Do you have phone number?
1 - 8 of 8 Posts
