Hey guys, this is my first post here.
On the automatic shifter there is a plate that covers the hole where the shifter travels. Well, that plate does not cover the hole any more....its like the spring is broken.
Does anyone know how to get under the shifter plate so i can look into this problem?
Read my post on how to access the change the gear selector bulb. This show how to remove the selector wood cover. Once accessed, you will have to remove the gear shift lever then open the gear numbering cover with a flat screwdriver.
http://www.benzworld.org/forums/messages.asp?messno=49279&id=10&view=t
...page 1 of the above post has instructions on wood covering and page 5, detail on how to remove the selector lever
..by the way.... welcome aboard
