1998 c230
This is a 1998 c230, it has small leak at the axle seal.How much of a job to fix, or suggestion as to how bad it has to be before you tare into it.
thanks
Does it drip on the ground, or is it just weeping?
There should be fill plug where you can check the level. As long as you keep the level up, it's not a problem.
1998 c230
thanks marvinstockman for the reply,and yes it will leak a quarter size spot overnight after having been driven.I drained and refilled with Lucus 75-90 and Im going to keep a close check on it. Thanks again.
mike
mike
i'd replace the whole damn thing before I pulled half shafts to replace seals. they gotta be a dime a dozen anyways.
1998 c230
axle seal leak
Thanks M10
Good idea,I thank I will just replace the whole damn thing. I need something to do before breakfast anyway.
Mike
