1 - 9 of 9 Posts
Ok, So my four switches are lighting up, but there is a fifth leg connected to the spider that must have go disconnected during my center counsel removal. I can not figure where the 5th leg of the spider goes to!?!? Any help.
Also, When I my cigar lighter isn't working and when I pull the ash try out the radio turns off? This never did this before.
Did you connect two to the Antenna switch, top & bottom?
Better go back in and check those wires. Sounds like the ash tray is grabbing the radio wires.
I turn on my radio with the light switch and fwd songs with the right signal... Volume is hard because is controlled by the left rear window switch...
Just kidding!! :p
I think you nailed it with the antenna switch, I haven't had a chance to check it. So the only think lit off the spider is the four switches?
That depends on what accessories your car has. Some of us have more than four.
But yes the fiber optics, on the 123, are only for the switches in this panel.
Details, details... So what are those other fancy switches for?
The switch with the dial is for the vacuum adjustable headlights and the other is for the fan fare or two tone horn of course.
1 - 9 of 9 Posts
