1992 Mercedes-Benz s600 v12
Hi there,
I just recently aquired a 1992 S600 Mercedes V12, and I'm trying to find answers to the current problems I'm experiencing.
Spedometre, Trip and Odometre don't work,
ABS light stays on on instrament pannel... these I'm not sure if they are related because of the sensor?
and aside from that, there is a high pitch squeeking while driving, and a very loud vibration in the car at times... if you tap the break it seems to go away for a second. I was told the breaks were redone and put too tight... but I'm concered it'd be more than that.
Any pointers?:(
1997 E430T
I'd inspect the brakes first and then diagnose the ABS problem, probably wheel speed sensors, but since your speedometer cluster is kaput it could be that, too.
All in all, it could be a very expensive repair.
SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Welcome aboard.. You will find plenty of information on here and help fron other 600 owners..
Speedo is driven from the font left wheel speed sensor.. If the brakes have been changed I would start to check there..
I would check to see you have the right pads fitted.. squealing.. could be due to poor fitting and no squeal shimms..
