96 C220, 03 C240
Whenever I go to turn my high beams on in my C220, all that happens when I push the stalk forward is that my lowbeams turn off completely, but my foglights stay on. Anyone have any idea what the problem might be?
95 C220
your car uses H4 bulbs which is double fillament... high/low beams on one bulb.
its either your lights (wiring) are incorrect/defective, the switch is defective or you're not turning it correctly... :dunno:
turn your switch to the right twice without pulling it towards you. it should light up your headlights....
if you pull the switch toward you once it turns on the fog lights, twice it turns on your rear fog lights
try also changing the bulbs first to check that it is not the bulbs that's defective...
when i got my car, the lights were the other way around... the forgs were the headlight and the low beams were the fog lights... had the seller fix it... saved me big bucks for noticing...
good luck! :thumbsup:
