85 300SD, 95 E320
welcome scabba,
i think this is what you were looking for:
1 No faults.
2 Oxygen sensor inoperative.
3 Lambda control inoperative.
4 Air injection inoperative.
5 EGR inoperative.
6 Idle speed control inoperative.
7 Ignition system failure.
8 Coolant temp sensor-open or short circuit.
9 Intake air temp sensor-open or short circuit.
10 Voltage at Air Mass sensor too high or low.
11 TN (RPM) signal defective.
12 Oxygen sensor heater open or short circuit.
13 Cam position sensor signal from-EZL/AKR ign. control unit defective.
14 Intake manifold pressure at start too low.
15 Full throttle Info defective.
16 Idle speed info defective.
17 CAN Data exchange-Malfunction between control units.
18 Adjustable camshaft timing solenoid-open or short circuit.
19 Fuel injectors-open or short circuit or Emission control system adaptation at limit.
20 Speed signal missing.
21 Purge switchover valve-open or shorted.
22 cam position sensor signal defective.
23 Intake manifold pressure w/ engine running too low.
24 Starter ring gear segments defective.
25 Knock sensors.
26 Upshift delay switch over valve-open or shorted.
27 Coolant temp sensor deviation between sensor ciruits 1 & 2.
28 Coolant temp Sensor
Code list above is for the DM / diagnostic module only. There's a half dozen or so other active pins with separate code lists in addition to the DM. I sent you a private message.
1990 300CE
The link i had posted before wasn't working. I reposted the working link.
It describes every pin error possible according to the chassis #. What you think about that as far as reliability for an accurate description?
