2001 C200 kompressor
this is my first Mercedes and my first time on this forum can any one help with this code thanks
'07 C280 4matic, '06 530i, '98 ML320
Very likely, MAF (Mass Air Flow) sensor is the culprit. You can try and clean the MAF with CRC [MAF] cleaner. If that doesn't resolve the issue, you may just have to replace the MAF sensor.
With that code set, I am assuming "check engine" light on the dashboard is on. Other than that "check engine" light, is the car driving normal and engine running normal?
the dash light was on, I reset it, it has not came back on ,the engine was running normal
MAF may be sending 'on the border line' data, the check engine light will come back. It's a matter of time...
In the mean time, at your convenience, you can buy CRC MAF cleaner and clean MAF.
