15 ML 250 BlueTec
Pulled the code above from my check engine light.
Any ideas what this might be? I can't locate it online.
Thanks,
Boris
· Banned
2015 ML250 Bluetec | 1987 560 SL | 2019 GLC 300 | Prev: | 2002 ML 500 | 2012 C250 | 1998 C230
Thanks,
Boris
Not a real code. Need to get a different scanner that's more compatible with reading this computer. Which one are you using currently?
More importantly, what are the symptoms and what is actually wrong with your truck?
Sent from my BlackBerry Key2 using Tapatalk
15 ML 250 BlueTec
Thanks for your reply. Oddly, no symptoms. The code reader is one my friend uses and is a MB specific reader (he's a tech who worked at the dealership for decades and now works at an independent shop). I was overdue for my BV maintenance and the light came on. Went off on its own, then came on again. He reset it and so far it has stayed off.
· Banned
Then see if it returns. Could be low voltage battery causing gremlins.
