I'm getting 2 faults that come back after I clear them:
Pin 8, codes 9 and 35.
Code 9 = O2S 1 (before TWC) (G3/2) sensor voltage
Code 35 = AIR pump switchover valve (Y32) and/or 23 28.0
electromagnetic AIR pump clutch (Y33)
Any idea what the next step is? Do I just replace the O2 sensor or might it just need cleaning?
I will replace the switch over valve.
Is the air pump clutch part #104-140-14-85-81. Is it easy to test?
1993 w124 320CE pre facelift 124.052
Thanks for your advice
