1 - 8 of 8 Posts
1999 ML430
Sometimes when I step on the gas at about 65mph to pass someone, the truck doesn't seem to want to go. It is also like this up hills. I want it to be like it should, press the gas and it goes, slam the gas and it takes off. But it isn't. Is there anything simple I can do to improve this performance?
ML430
How many miles are on your 430? I have the same year/model as you, and i use fule injector clenaers about every 2 other fillups (I travel a lot and have 109,000mi on mine). But mine does no seem to have that problem. It will get up and go whenever (sometimes when i dont even want it!). Good luck.
1999 ML430
I have 84k on it now. Any recommendations on brand of FI cleaner?
Mercedes "M32"
GLisella - 3/19/2005 6:26 PM
Lucas Fuel Injector Cleaner works great for me ... I use it every few tanks.
05 500
ttaleric - 3/19/2005 10:05 AM
You really use fuel injector cleaner that often? Do these things do more that clean the injectors? Is it a problem with the motor or the fuel? That sounds like a lot.
2014 ML350 BlueTec
l remember sometime ago..that someone of this forum mentioned that fuel injection cleaning products has a adverse effect of the converters....l've always used them..Any thoughts ?????
2000 ML430, 2000 C280
I heard that the pre-2000 Mercedes automatic transmissions are slow to downshift, thus causing a noticeable delay when passing. My 2000 ML430 takes off immediately when passing. Try downshifting manually.
DelJ
GLisella - 3/19/2005 6:18 AM
1 - 8 of 8 Posts
