Go to www.autohausaz.com Click in all the yr. make, model info for your car. When the parts menu pops up, go to "Belt Drive System"
All of your replacement parts are there. Idler pulley/roller is listed as part#6012001070. Out the door for $31.72
If you are a DIY'er, make sure you loosen the big nut in the middle of your belt tensioner before backing off the adjuster rod. If you miss this step, you most likely will need a new tensioner and adjusting rod. The tensioner is about $100 bucks.
Trust me, I made the mistake - once!
good luck,
Jayare
