Hi all:
No matter where I position the fan direction dial it will only low out the defroster.
Any DIY checks I can do myself?
Thanks,
Mike
Hi all:
Thanks,
Mike
You will need to replace the Defroster Actuator Motor. Remove the underside sound panel and then the driver's r/s kick panel.
Remove the ETC Module which is held in place by a spring steel clip. Then remove the ETC bracket and the actuator is behind the bracket.
I had the same problem and found that the lever on the defroster actuator motor broke once I had gotten to the motor. The lever cracked where it attached to the stepper motor and the motor was unable to control the defroster flap.
The new part # A 163 830 10 33 seemed to be made of a different plastic which was stronger than the plastic used for the old lever.
I bought part # A 163 830 10 33 for around $25.
I did not need any equipment to calibrate the defroster dial. I just replaced the lever and put everything back together.
It took about an hour and a half to do the job.
Joe
