1 - 9 of 9 Posts
97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Fast960,
What's the refill fluid's name (brand) and where can I but it?
1998 Pano SL500
Moderator
SL55, 300SE, GL450, Daytona 955i
The fan clutch is crappy and fragile by design, I doubt a fluid change will make it any better... worth a try though...
... I doubt a fluid change will make it any better... worth a try though...
I have my doubt too. I just want to experiment and find out first hand if the fix works. I have 2 defective clutch that I replaced from a 94E320 (Behr) and from a 93 500E (Sach ,sp.)
1998 Pano SL500
As far as this example states, it's not a fluid replacement but a fluid supplement ... adding 18ml to give the clutch more grabbing power
Moderator
certainly worth a shot... let us know...
1998 Pano SL500
update: no drilling required
I haven't done the mod because my temps are cool now however I have found that no hole needs to be drilled for our model fan clutch .... just removing the press-fit pin and filling there .....
Another r129 owner posted good results with this in another forum (although I would only put in 10-18c for a rejuvenation)
http://www.peachparts.com/shopforum/sl-forum/94977-viscous-clutch-fan-repair.html
Cheers,
Fast960
1 - 9 of 9 Posts
