1 - 10 of 10 Posts
I am having an issue with my cooling fan it is running at high RPM sounds like a jet engine fan. I did the scan and it gave be coolant temperature senor 1 fail error, but there is no CEL and the instrument dash gives a proper temperature.
After, I shut the car off the fan continue to run for another 30secs.
I recently did a flush got 7.5L out and added 50/50 Pentosin.
Any thoughts
Cheers,
Pin2
Witek - I tried to clear the code but was getting an error, originally I had tried to clear the code since I was doing the flush I also upgrade my headlights to LEDs so I had a bunch of codes. I cleared it but at the time was running and idling in park, I knew I messed up because the key position was not on 2 or (on) state. The Fan spinning started at that point, I have the Foxwell scanner with MB SW but it won't allow me to clear the code.
Pin2
Where is the fan relay located I looked at the owner manual and there is no description in which fuse box has the relay?
I think it's a bad relay that is stuck and causing the issue.
Cheers,
Pin2
Pin2
What year and model?
Here is the location.
Hey 43sqd,
Thanks for the details is this for sensor 1 or 2? Also, where is the fan relay located is this something that you can provide?
Pin2
Any thoughts
Cheers,
Pin2
Fan screams on high because of fault in ECM for faulty coolant temp sensor.
1 - 10 of 10 Posts
