Haven't posted in awhile. First off, just want to thank all of you for the wealth of knowledge from members that's on this site. I've advoided countless inflated dealer repair costs by following threads and doing it myself. Thanks :thumbsup:
I've been dealing with the MAF sensor problem that I'm learning/reading is a hot topic. I have the same issue.. I cleaned the sensor and removed as much oil from the system a year ago when I first started noticing poor engine performance and an engine light. Took the car to do the dealer and was given the OBD codes and was given a big estimate for the repair which includes replacing the PCV valve and basically the entire MA system. Doing it myself, luckily the cleaner worked, light went off, car ran great afterwords, and the car was trouble free for another year.
Light came back on months back and rather then returning to the dealer, I took it to a shop for OBD codes(see if they were the same from last time) and to see if it would pass VA emissions. It failed.. OBD codes are;
P0170 Fuel Trim Malfunction(Bank 1)
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0300 Random/Multiple Cylinder Misfire Detected
I cleaned the MAF sensor again(oil was on sensor again) and cleaned as much of the oil out of the system as I could. Car ran much better, check engine light did not go off. This time around, I forgot to disconnect the battery. Haven't ran the car much since the repair. How long might it take? Should I follow the procedure for disconnecting the battery to reset the light? If it persists would you guys recommend replacing the MAF sensor?
What about the root? Has it been determined that the presence of oil in the system is in fact due to a bad PCV valve? If so, how difficult is it to replace the PCV? Anyone done it and if so do you have instructions? I have not used K&N filters by the way.. Thanks in advance!
