I'm new to the forum and hoping someone can enlighten me.
I installed a used 04 Sirius unit, splitter and antenna (according to forum directions and pictures) in my 2006 E55. The install was pretty much straight forward. The issue I'm having is the Command Unit does not see it. I press Sat and the Head unit/Command say No Satellite Radio.
Is there any programing that must be completed in the Command to see the new unit? Any help would be greatly appreciated...
:thumbsup:
2005 E-320 CDI Sedan, a W-211
What I Did . .
When I tried to do the very same thing to my 2005 W-211 CDI,
I found my Diesel did the exact same thing!
What I had to do was go to the dealer and have them set it up so that the
Command recognized the 'new' modul, and then everything worked fine.
My local dealer was reasonable and I was charged only $150 which included the
best dealership car-wash I've ever had; Almost a full detail to be exact.
Go ahead and do as I did as I know of no other way to fly. Good luck.
Regards,
DHG
Is there any programing that must be completed in the Command to see the new unit? [YES!]
:thumbsup:
His - '09 ML-320 Bluetec, Hers - '05 E-320.
Do all of the E-class come with the wiring harness? I'm not seeing my connections in the trunk of my '05 E-320.
Some Do; Others Do Not
At least that's what I have read.
My W-211 was built in November 2004.
I've read that the 2006 MYs did not have the wiring set up for the trunk lid. Mine did.
It's VIN is 721xxx.
HTHs
DHG
2006 CL500, 1999 CL500, 1999 Audi A8Q, 1999 BMW K1200RS
Any other input on this issue? I have an 06 CL500 with a factory sat radio that is not recognized by the Comand system.
