1 - 10 of 10 Posts
I am smell exhaust inside the cabin of my 300 sdl on occasion, nothing powerful just enough to know it runs on diesel.
Is this normal? Is there anything I can do to decrease the smell?
450 SL 1976
My old 500sel had that problem (though it wasn't exactly a smell of diesel[:D]) - it turned out to be a leak in the trunk; the hatch wasn't fully adjusted...
So when I had the sunroof or a window open, the exhaust was sucked in to the trunk and the cabin because of the under-pressure... a little adjustment of the hatch took care of that problem![:)]
Moderator
1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
Hey Thomas,
I think you are one of a handful of individuals I'm aware of (I guess I don't get out much!) that recognizes the fact: when a window is opened (while driving) it causes a negative pressure/under-pressure inside the passenger compartment. Draws fumes in through the trunk as exactly as you say.
"Oh, You have a broken exhaust? Just open a window a bit, you'll be OK.
I'd heard that from customers at the dealership, & well meaning non-car enthusiasts..... seemingly forever....... I'd say close the windows & put the heater on, temp cold & fan on low.... Non climate control days of yore.
For some time, I've the privilege of driving a closed, large displacement, '30's British motorcar several times each year on tour. When it is warm out & we've been on the road (60-70 mph) for a bit -------- well one wants to open the window at times. If you do, the combined exhaust & rear mounted fuel tank fumes can be really something, even with the cowl vent (front of the windscreen) is open.
I'd not given a thought to the sunroof. Looking at my wife's car yesterday, I'm sure it is due for an adjustment.
Thanks for the reminder, MBL
Audi A4
Is it serious problem?
I have 1988 420 SEL, and I also get exhaust smell in a car occasionally.
My friends just make fun of that as “old-car smell� or “smells of 80s’ car�.[:D]
A
Guest
Check to see if your flex pipe that joins the two exhaust manifolds together, is not leaking.
Passenger side of the engine, in back and below the
turbo.
W126C AMG 6.0
What do you mean by adjusting the hatch? I have had this problem and it is indeed when the windows are open. I knew it was coming through the rear but how do you adjust the hatch? New seal?
450 SL 1976
EuroCoupe - 3/9/2005 1:15 AM
Well, I'll give my best shot at explaining it... with my school-english!![:D]
My hatch was adjusted too far from the rear window, resulting in a "hole" at the back end of the car (by the numberplate/rearlights). If you open the hatch, you can adjust it were it is attached to the car (you know - the thingys that go up and down, so it's possible to open/close the hatch![:D]).
There are bolts in both sides, and by loosening them, the hatch can slide a little bit...
I hope you understandmy pretty poor explanation!![:eek:)][:D][:D][:D]
87 420SEL, 89 560SL, 92 300TE
Thomas... please do not apologize for your English- you are quite understandable and I would be willing to bet that you speak better English than any of the native English speakers here speak Danish (Dansk?)!!
I believe the parts to which you refer are the trunk (boot) lid (hatch) hinges. The trunk lid can be adjusted on the hinges by loosening the screws you described. A new trunk seal might be a good idea also, as the originals are becoming rather "elderly" and OEM replacements are under $50. Also, if you have this problem or a "wet trunk", check the seals on the tail-lights - they are a common source of trunk leaks.
-Robert
450 SL 1976
OCStrider - 4/2/2005 6:55 PM
HAHAHA!!! I'm pretty sure you're right!![:D][:D][:D]
And yes - it's called "dansk"...[:)]
I only apologize 'cause I myself think my english sometimes is poor; sure I can make myself understandable, but as you noticed (boot lid ... offcourse! I knew that!!! just couldn't remember...[;)]), some words just are hard to find... [:)]
1 - 10 of 10 Posts
