1 - 20 of 20 Posts
G
I have a clk430 -w- the clk55 dual tip exhaust on it. It sound good, but I'd like a bit more rumble. Don't want it to loud. Has anyone removed the resonators. How much louder was it? THANKS!
G
Re: Where did you get the CLK55 muffler from? I presume it's not the entire cat-back system?
I bought it from Auto Class, it is cat-back? Any ideas?
G
G
Discussion Starter · #5 ·
I haven't seen the one from Autoclass. If it's cat-back, it should have had piping from the muffle
muffler all the way to the catalytic converter. However, since you're inquiring about the resonator, which comes after the cat, then I presume it's not?<br> <br> Have you had it installed?
G
Discussion Starter · #6 ·
Oops, you've had it installed...I just re-read your post.
Is there a big diff. between the AMG exhaust and stock exhaust?<br> <br> Tea had his resonator removed.
G
Discussion Starter · #7 ·
No, it is not a cat-back just the muffler
If you want it to be louder I strongly suggest you to remove the resonator.<br> It sounds great IMHO
G
Discussion Starter · #9 ·
Re: No, it is not a cat-back just the muffler
Yeah, it's just the muffler. How much louder than stock was it. Is it really loud when cruising on the highway?
G
Discussion Starter · #11 ·
Re: It is not that loud when you are cruising.
Did you notice any more power. I don't want it to sound like a tricked out honda either. Can you be more specific like idle, acceleration, etc?<br> THANKS!
G
Discussion Starter · #12 ·
Re: POWER?
G
Discussion Starter · #14 ·
It's a trade of you'll gain top end but lose a little on the low end
And for the sound? That is one V8 sound that Honda definetely can't produce!<br>
1 - 20 of 20 Posts
