C320
:rolleyes: Salam aLL
Guyz what is the recommended inches for C320 exhaust , for better airflowing and speed good also not getting temp up below?
i have tried 2,5 with taking off the powerflow silencer but heat up in middle then i put back the powerflow and its fine ....
suggestion , opinion , selutions plz
C Owner
2006 C280 4Matic
Re: exhaust
if you're looking for the proper airflow ratio..unless you plan on supercharging the car...you shouldn't go past 2.5 piping. you can remove the mid resonator...but I suggest if you're gonna go cat back....replace everything with
hi-flow performance cat back piping....I believe Kleeman, Brabus and Lorinser make them.
