G
Guest
Any one ever change the manifold flex coupler
that joins the two segments of the exhaust manifold together. Mine has a leak.
It appears that it is going to be a real bear of a job.
I have new studs ordered; hear these are easy to break.
Also on order are the copper nuts & exhaust manifold gasket.
It looks like I'll have to remove the turbo, is there any O-rings or gaskets I should order for that.
Also on order is the coupler,inner sleave and the
2 coupler clamps.
A
Guest
Discussion Starter #2
I did a search under corrugated and accordian
exhaust system and found nothing.
I would try mercedesshop.com forum
