Hi all,
I have a 2003 vito traveliner 110cdi, exhaust gone next to cat after a couple of welds. been quoted stainless wihtout cat as mate has a 2003 VW t4 with similar and been o.k. with MOT. conflicting reports but as full system replacement which I need so expensive cheaper to go stainless without cat. When I mot'd last time mentioned exhaust and they said 'probably o.k. without cat' but could do with other opinions. help appreciated.
cheers
mark
I don't know enough about Vitos and MOT to comment accurately, but as for removing the cat in newer vehicles, check carefully that there are no sensors downstream of the cat.
v220 ambiente
Hi
I am fairly certain Mot on diesels is only for smoke so it doesn't matter about cat for this. The early vans did not come with cats whereas the V class all did from the beginning.
G
Vito 112CDI
De-catted my 112CDI - no probs with MOT...
Go for a 'custom' exhaust with someone like LONGLIFE - well worth the money, lifetime guarantee, have a sporty grunt and a bit of extra va-vroom (especially when de-catted)!
FUZZ
Thanks all, just rec'd this info so hopefully will help others
A catalyst is not a legal or MOT requirement on any diesel engine so it would pass the MOT without one and have no bearing on it at all . some later diesel vehicle are what is known as "clean Burn" . these vehicles are fitted with Diesel particulate filters and have nearly zero emissions , if you have one of these vehicles (normally around 2007 2008 and 2009 it could be a grey area as these veheicle get reduced road tax
:):):) steel for me then and money in the bank to boot
