So I got a rust-free 115 to drive around while I finish the 123. 76 300d, all in all a very nice car. HOWEVER--im a mechanic by trade, and I know 617 123's like the back of my hand. So I open the hood after I get the car home and I can't find the oil filter housing. It's a big can, you can't really hide it anywhere, so unless its on the bottom of the injection pump (highly unlikely), the previous owner REMOVED THE WHOLE ASSEMBLY and spliced the lines together. The car runs like a top and doesn't burn any oil, but if the oil filter has been removed, that motor's coming out and another one's going in. And it's gonna have a turbo
Is a 123 turbo 617 compatible with the 115 617 mounts? anything i should know before starting this?
i know the trans on the 115 has a downshift rod instead of a cable/vac valves, and it starts in 2nd gear, and i believe the turbo version has a stronger version of the 722 to handle the increased power output...so maybe a trans swap is in order as well. driveshafts compatible? and if both cars have 115mph speedos, does that mean they both have 3.07 rear ends?
