No special tools. I had to fabricate a radio removal tool using an old credit card and I used a paper clip to to remove the glove box lock. The trick is you turn the key to 45 degree angle and insert the paper clip in the small hole and pull the cylinder with the key. It's very easy. Or you can just purchase the radio removal keys online for $10.00
I used a hanger as a hook to pull the instrument cluster from the right side while I pushed the left side with my left hand after removing the left vent. I'ts so much easier that way. If you need any info, I have detailed files. I did 3 weeks research before I did the job.
