1 - 10 of 10 Posts
92' 500SL, 87' 560SL, 93' S500 C140, 91' W126 260SE, 94' W124 E420
Hi,
Could please tell me whether the Euro bumpers & Euro headlights of the SLC are any different from the ones of the SL?
Thanks!
Chris
1973 450 SL
The reason I ask is, the ROTW lights on my car came from Australia, a RHD market. Fotografa told me they were wrong for my car because of the lenses. I researched the Bosch knowledge website (when it was working) and downloaded everything they had for R/C107 headlights. I did find different order numbers for the lenses. Foto was right but I can't see the impact when I drive my car at night.
· R/C107 Moderator
1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s ALL SOLD
Interesting. Bosch part numbers for LHD are 1 305 620 113 left and 1 305 620 114 right. Can you look at yours when you get home?
'80 450SLC Afro RHD Ikonengold, '01 113 W638 'Liz Hurley'
I actually remember that one as I spoke with Foto at that time.
The LHD and RHD non-US lenses have mirror shape pattern because the low beam casts more light against the kerbside (US is flat). See here
The other difference is that the stock H4 globe is used for both RHD and LHD - it is rotated by an angle to create inverted pattern.
To convert RHD <--> LHD mirror on 107, globe seat may be all you need to replace on the mirror (it is removable) and hopefully use one from the more abundant 116, or similar.
Additionally, new LED globes are coming much better nowaday and some can rotate in their seat making it all simpler.
I just got ordered H4 LED globes with clear shape as per ECE and previous reporting suggests that the light casting is by far better end more even (no shading that is observable). Seeing is believing, for the cost of less than decent H4's it is worth a trial. Worst case they will end up in my semi-project van Vito 638 at work which strangely uses H4 globe for fog/high beam and a separate H7 for low beam.
73 and 75 450SL,81 380SL,80 500SL, 85 500SEC and 81 500SEL.
I can confirm that the reflectors are different, I tried adjusting to suit rhd and found out you cannot. Luckily I had bought a set of rhd reflectors so just swapped them over. Rhd lenses end in 123 and 124 and lhd lenses as Rowdie stated 113 and 114.
1 - 10 of 10 Posts
