Heys guys i wanted to know what the largest ET is that can be mounted on a w108. I was thinking a 17 inch wheel. Any help would really be appreciated. Thanks
1965 220S, 1999 Volvo V70 (wagon), 2006 Ford Crown Vic Police Interceptor, 72 350SL 4 Speed
The extra wide 18" wheels use approx 11mm ofset. The real question is will the tires rub on the front fenders and suspension components.
Which W108 do you refer?
Its a 1972 280se
[/IMG]
I just dont know enough about wheel fitment to determine what i can get.
I was thinking of lorinser rs90's
Wheel size and offset are two different things. I have 16" wheels on my '72 280se 4.5. They were too large of an offset, so I used spacers from H&R. They fit fine in the wheelwells. Look at Cox Groups 111 chassis with 18" to see that anything is possible.
W111 Coupe
offset varies with the width of the rim. I believe that stock 5.5 inch wide are 31 offset, while 15x7 are 25 offset.
Offset is relative to the center of the rim. So it depends on what you have to clear and on which side. You have more space towards the outside, so the wider the wheel the smaller the offset.
i
