2005 E 320
I am getting a ESP warning after i changed the shock, is something damaged or just need to be reset? i did not unplug battery during procedure.
Super Moderator
Probably just reset. Make sure all sensors and wires are intact before taking it in for the reset.
2005 E 320
disconnected the brake wear indicator. pumped the brakes, reconnected and problem was solved. just as a note we never disconnected anything but the air shock assembly and associated lines during the repair?
