Discussion Starter #2
That is normal. It's MB's disclaimer to let you know that the ESP is off.
You may also notice it flashing, which is when it automatically turns back on if you are slipping too much.
Best to leave it on
Yes, it's normal when you turn off ESP and light comes on in the MFD. It's only abnormal if no matter how you press the switch (on or off), the light stays on.<br> <br> FYI, with ESP off, only engine intervention is cancelled. ESP, BAS, ABS functions remain the same. This not the same as the system found in BMWs.
