1 - 10 of 10 Posts
Zotye Auto 1.5T T600 2016
The fault code relates to secondary air injection switch over valve and not the MAP sensor, you do not say which model and year your car is.
ah, yes, its a '01 200K.
"secondary air injection switch over valve" - Where can I check this?
Can you give me the vin#? 01 200k does not help with WIS.
Hi Eric,
Have sent you a PM with my vin,
thanks
Well I normally deal with the big engines but I believe this is what you should be looking at;
Great, thanks!
Did a search now that I know what I'm looking for and found this (it might help someone in the future) :
I had this disconnected yesterday, I'll check the connections.
Cheers!
Steve
Great, thanks!
Cheers!
Steve
If you removed it yesterday make sure it was put back the right way around as this is a one way valve.
And make sure this switchover valve is connected properly.
solved. Thanks for the advice.
I had the car on a lift and looked up under the intake manifold... a connector had popped off the sensor on the bottom... gah! Engine light off again now. ;)
1 - 10 of 10 Posts
