Before you go buying a new injector ohm test them and compare readings. I had the Po170 with a #3 malfunction and if was the MAF. Has this ever been cleaned or changed?
I am sure the Maf wonder boy is on his way. It may be a case of cause and effect.
You should also pull that plug and check its condition as well. B
