1 - 1 of 1 Posts
Good afternoon,
I have a 1999 CLK320 coupe and just the other day the Check Engine light came on. The following error codes were received: P0450 (Evap Emission System Pressure Sensor Malfunction) and P0400 (Exhaust Gas Recirculation Flow Malfunction).
On a different website (justanswer.com/mercedes/7mt9j-mercedes-benz-clk320-need-no-part-need-code.html) it states the following: You will need an EGR valve and tube for the P0400 fault code and start with a purge valve for the P0450 fault.
Has anyone had the error codes listed above and, if so, where did you start/end in getting the issues fixed?
Thanks in advance for any responses given.
1 - 1 of 1 Posts
