1 - 9 of 9 Posts
2009 C220 CDI / 2003 ML350
Hi All
All three the following light are active on my dash:
"BAS/ESP" & "ETS" & "ABS"
Braking seems to be fine but I am worried it may be something big :(
Any suggestions as to what it could be?
99 ML320 2000 ML55 AMG... miss my 84 500sec AMG
DO A SEARCH!!!!
There is PLENTY of READS on this topic!!!!
Search in this W163 forum
2002 ML55 AMG, 2005 Chrysler Crossfire Coupe Limited, 1999 C280
I hope it's something as easy as replacing your brake light switch.
Otherwise, I hate to tell you that you are in for a bruising, time consuming, frustrating and expensive diagnose and fix.
Discussion Starter · #5 ·
Super Moderator
You priced the ABS pump for the brakes an it is about $1496 at parts.com.
The wheel speed sensors are around $85 apiece.
Outstanding Contributor
2006 ML500 2002 ML320
Why don't you just have the codes read with a professional grade scanner, instead of suspecting what it is and foolishly spending thousands on parts.
Discussion Starter · #8 ·
The codes found by the scanner:
1) CODE001:p20CC 'Rough road detection' signal (by comparing wheel speeds)
2) CODE001:p2600 The voltage supply of circuit 87 has undervoltage
3) CODE002:p2400 The right rear wheel rpm signal sent from the traction system via the CAN bus is implausible
4) CODE001: P1860 Traction system RR wheel RPM error
The wheel sensor was replaced but did not resolve the problem. The mechanic then said that the ABS controlled is faulty :(
I agree that if I can find an affordable solution it would be great.
again thanks to all for your support with this problem
Dallas, Texas
1 - 9 of 9 Posts
