Hi, i have a problem every morning now when i go to start my car the epc light comes on and the car only starts on 2nd or 3rd turn, but starts and epc light stays on, if i leave idle of a while and come back and restart usually it starts fine and everything ok until the repeats next morning,,,,, got a reading on the computer and it says brake light switch ?? any ideas also glow plugs come on after driving for 1/2 hour may the problem is lined and i need glow plugs replaced,,,any suggestions welcome oh one last thing i was driving a couple of time and the brake loses power and is like pressing the brake when the ending is switched off,,,,,,possibly all related, thanks for reply
1998 c230 170K
The brake light switch is under the dash right above the brake pedal stalk, its a somewhat common replacement item. The lack of brake power assist problem your having needs to be fixed before you drive the car anywhere. It may be a combination of problems such as bad brake booster/vacuum leak, air in lines, ruptured caliper seal, broken brake line.
I am not a guru on diesels but your starting problem may be related to the glow plugs. My advice is get the brakes in working order first before someone gets hurt. B
