E350 4M 06
This morning the CEL came on and it took the temp gage 30 minutes at 77 MPH to reach 80 C, MPG was 22.2(normally 24 to 25 MPG).
I assume its the thermostat, I checked around and the dealer wants $140, another store with the Wahler brand is asking $118. Both include the AL housing.
Please confirm that Wahler is the OE brand.
Anything to watch for on this wrenching job?
Thanks a Bunch
E350 4M 06
Discussion Starter #2
I bought the Wahler thermostat from an import shop, the one on the car is a Wahler also, it looks like I need to remove the air pump and belt to get at it.
(I love this self help forum, you get to ask a question and then answer yourself a few hours later)
The big question now: Should I put gasket RTV on the rubberized gasket?
May be Roadking knows the answer? Well find out tomorrow!
2007 E350 Sedan
It has been a while since I changed a thermostat-any thermostat. The last one I changed had an obvious problem physically, in that there was a crack in its "base." Am assuming your shows no signs of such a problem.
The test used to be to put it in a pot of water and heat the pot up with a thermometer to see if it opened close to specs.
Curious as to whether you plan to check what you have in that or in another fashion.
Sorry that I am not a help on your gasket question.
E350 4M 06
Thanks Jimbo,
I remember in the good ol days when thermostats went on sale for $1.99 and you tested the old ones with a pot of boiling water.
Things are a bit different now, the thermostat was a good deal at $118 plus tax and you plug a wire connector into it.
I just finished a DIY sticky on the subject and posted it in the Sticky section.
The old thermostat had a gap in it, so there was no need to test it (Look at the picture in the sticky)
Thanks again for responding
