2000 e320
Does the engine temperature sensor control the cold start fast idle. On a cold morning my car starts right up to about 1200 rpm but within 30 seconds drops to 800 rpm. Is this normal?
1998 E320 base sedan @ 160kmiles
Yes it does, and yes it is. What does the gauge read when you start the engine when it is cold ?
2000 e320
The gauge shows it is cold, needle all the way down. I know you have been trying to help me with and I thank you. It just runs so good after the first start in the morning. I may be thinking old school with watm ups. It just seems to idle down so fast. No different then summer.
2000 e320
Green '02 E320 Wagon
To access the climate control diagnostic display, press and hold the REST button (which disables the A/C) until the climate control screen changes to show a 1 on the left and the in car temperature number on the right. Use the left and right Auto buttons to cycle through the different data points. You want #6 for Engine Coolant Temp. The list of codes is attached.
