1994 E320
Finally got to check out the car today after doing an engine swap..Works beautifully, the swap was a little crazy but everything seems to be working just fine now, no lights on the dashboard................:)
2013 E350 sedan, 2013 E350 cab, 1993 400E sold,1999 ML320
With the old engine you had more than 1 light on the dashboard? Other than the check engine was there something else? Why did you have to swap the engine?
About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, 4Matics and 1 coupe
You took the original engine out and installed what in it?
1994 E320
i aquired the car from a friend of mine because his friend while changing the valve seal or head gasket not sure which one damaged the camshaft. Buying the parts wasn't worth it so i found a used engine and swapped it last weekend.......;)
