I have an issue where the engine just stall in the middle of driving, basically all dashboard lights come on and the car shuts off.
I try to start engine but nothing. After about an hour, the car starts again.
I checked for codes and noted p0335. I read other posts where people suggested replacing CSP and I will do that, however I'm wondering why would it start again after an hour, it appears as it has to do with the engine cooling off. Would the sensor overheat cause it to mulfunction or is this a simptom of something else?
Any thougths?
Crank sensor is made of steel core with half mile of super thin wire wound around it. When it gets hot wire coil opens up. When it cools off it makes connection again.
Add vehicle info in your signature. ;)
