Hello,
I need your opinion on this one. The SL started fine & went to the petrol station to fill her up & from there went to a restaurant.
15 Mins at the restaurant- I went back to the car
The problem
1) Engine shaking & sounded like a motor boat( RPM goes up & down violently)- I panicked & turn it off & restart the car- Same thing- Engine shaking sounded like a motor boat &
I just shift the gear to "R" the battery light come on & the car engines automatically shut off. I start it again & do the same- I move forward a bit "D" & Try to engage the "R" the engine shut off- Battery light comes on.
So I call my dad for help & waited for 15 minutes. We start the car again- Engine shakes a little & Try to engage to "R" bits of shaking & shift the gear to "D" the car is back to stable.
The car performs "OK"- No shaking, RPM is stable- Looks like nothing is happen.
So my dad & I test the car one hour later- The car starts fine with no problem. Car goes smoothly.
Cliff- Engine shaking + Sounded like a motor boat+ RPM goes high up & down + Battery light & car shut off. After 15 mins- Started Car: Engine a bit unstable but it didn't shut off & goes OK. Everything is fine after that.
Any Ideas?
I'm bring to a tech tomorrow to check & also will ask them to install the EHA valve that I ordered few weeks back.
The problem
Any Ideas?
