1976 MB 450 SL
When I take it up to 85 mph it misses really bad. Has slight miss at idle. Runs great in between. Does anybody have an idea of this problem?
BenzWorld W126 & W201 Host
1988 420SE, 2002 C180 Kompressor, 200 ML320
Misfire
jrblackie
It could be any number of things.
If you are cruising at 85, does it miss, or is it when you are giving it acceleration [?]
If it is when accelerating, does it do it if you floor it (when warm) from lower speeds [?]
1976 MB 450 SL
miss
Actually, it happens anytime I bring it up to 85. I'm thinking that it probably has to do with fuel, as I did a complete tune-up (plugs, wires, cap, rotor, but no coil). My guess would be an injector or fule distributor. But I'm no expert, just trying to learn about this beautiful car of mine.
jrblackie
From what you describe, it won't be an injector and doubtful it would be the ...
jrblackie
From what you describe, it won't be an injector and doubtful it would be the fule distributor.
What is more likely and more common is the fuel pump/s and filter.
Check the fuel filter situated underneath in front of the spare wheel well. These quite often get neglected and never changed over the years.
Replace the filter and then try it before looking at the pump/s.
[8D]
380 SL
jrblackie,
I agree with Spanners. I had the same type miss with my 380. After I chang...
jrblackie,
I agree with Spanners. I had the same type miss with my 380. After I changed the filter, no more miss.
1976 MB 450 SL
Filter
I tried the filter and I still get the same. Do you think it could be the pump?
Mis fire
jrblackie
From your description, it sounds like the pump. The only thing that concirns me is that i would expect it to miss if you floor the accelerator from lower speeds.
