I was doing some anti-rust work on the car for the last few weeks.
Now water is getting inside under the hood on both sides.
(likely enough to cause electrical problems if its a storm while on the road).
90% of the water gets in front of the fuse-box area.
Usually I had the hood in the vertical position like in the photo & perhaps lost some insulation rubbers?
e.g: on the right side there is a black rubber mounting extending from in front of the water washer reservoir to behind the coolant reservoir.
but there are no such rubber mountings anywhere on the left side near the fuse box or in front.
Anyone have the part numbers for those insulating waterproof rubbers so I can find out whats missing?
