Registered User
2006 S500, 2003 ML350, 1996 C280 (Previously 2002 CLK320, 1995 C220, 1980 300SD TurboDiesel)
have any of you ever flushed your engine yourselves? I'm kind of sick of all the black oil aka dirt in the oil I guess. Is it highly beneficial to have those deposits removed etc? Is it a difficult/expensive process.... cheers!
300 SEL- 190D- 380 SEC
Not too familiar with that phrase yet if your speeking of cleaning the oil up heres what I'd do. I've done this once in my 190 D. 1/2 a bottle of tranny fluid* + your current oil, run it for 5-10 minutes. Then drain the oil and use Amz-oil()i think thats how you spell it Remember its a Desiel it'll always get black.
Why tranny fluid? it is a very poewerfuldetergent, I would suggest you make sure you dont touch any painted surface after handling it...dont ask. [}:)]
Depends on the day!
I've had good luck using Risolene on dirty motors.. About 100-200 miles prior to an oil change I'll dump a quart in.. Oil that comes out is Black as night.. Let it drain over night.
ATF also works well as noted above.
Jonathan
