2002 CLK 430 & 2001.5 Chevrolet Silverado Duramax EC/LB LB7
Here is the run down:
Car has 89,000 miles. 2002 CLK 430. I drive it less than 5,000 miles per year. Having some ticking from the valve train. Not really wanting to break into the engine as the noise is very quiet most of the time, but is still present. Especially on start up the noise is much more prominent almost if it was a knock. Once warm, the noise is almost gone completely. Now if I start the car in the morning and back it out of the garage and turn it off, when I go to restart it an hour later I will sometimes have a brief puff of blue smoke and the smell of burned oil. It does not do this if it has been completely warmed up to operating temperature, ever.
Question:
Would a flush of all the engine oil with a detergent cleaner help out with the valve noise? Would changing the viscosity of oil help prevent the oil that is leaking out on those short runs? What oil would you use? Finally, can I go back to dino oil since I never drive the car that much in the first place?
Thanks!
-ZRT
Question:
Thanks!
-ZRT
