1 - 17 of 17 Posts
The previous owner had removed the fan from the engine and i cant find the bolts to reattach it. anyone know the part to search for a 2000 e430?
2620475
thanks, wouldve passed smog but not with out this part lol. i even tried to install at the bolt store next door, but couldnt tighten the bolt head down at that angle and no 10mm socket doh lol every fan blade has a chip in it too, i was just hoping they could pass me to get up to date tags,
1998 E320 base sedan @ 160kmiles
What does radiator fan have to do with smog ? Your car has electrical aux fans in the front. I recommend that you get new blades and bolts and install the blades to the visco fan clutch. It will reduce the demand for the aux fans when the engine gets hot, or when the a/c runs.
California, they said that they couldnt ok it... so then i barely got on the broke one, and that just made it look worse because the bolts i bought couldnt screw in all the way. oh well, parts will be here by next wed... glad everything else passed. they also pointed out where a wire was slightly chewed under the engine cover, i should probably use something other than gorrila tape right?
I think that is BS. How can a fan removal affect emissions ? You should install it, but ask them which CA emissions standards that the car failed. And install the proper bolts, and a new fan blade unit. If the old one disintegrates, it will damage many things under the hood, including but not limited to the radiator.
i think it was under visual inspection same catagory as the exposed wire.. i was thinking the same thing, that it could cause serious damage. although the clutch on it keeps it from spinning too fast right? he said that the other smog guy would be there today and might pass it... haa, only problem is getting this broken fan off as i dont know if i have a 10mm socket or if it will fit over the bolt as the correct part is ala wrenchable.. maybe some bent needle noses could work but dont have a pair lol great
I think you run into technician trying to give you hard time, unless you bought salvage vehicle and had technical inspection.
Smog test visual applies to emission system, not to luxury equipement. That said I drove my E300DT with no engine fan for years, while living in California and going to Vegas for vacations.
Gasoline engine generate more heat, but depends what part of CA you are in, you might get away depending on electric fan only.
Just borrow tools to remove the whole fan clutch from the water pump shaft, and remove / repair outside the car. Else you can easily damage the radiator. Remove the fan shroud, so you have more clearance. Also check the fan clutch and replace it, if it is not up to par.
1996 SL500, 2000 E430
I once took a friends 86 Toyota pick up in for a smog test and it passed in emissions but they failed it because there was two openings for a vacuum lines on the carburetor but were not used.
So to play the charade I went to an auto parts store and got some vacuum line and a T fitting and hooked it up to a vacuum line.
as the car gets older I forget the test certification it is but a technician looks in the engine and if anything is not stock they fail it.
A part has to be CARB certified.
now what I don’t understand is I took my 2000 E430 for a smog ( Sacramento) and they just plugged into the OBD plug and determined it passed smog.
and admittedly I haven’t read this thread is intently as I should have but how did you get the car there when the bolts were a problem on the fan blades?
that fan blade comes off and it’ll just destroy the radiator.
hopefully that will be it and not hurt other components.
as others said use the proper bolts and I just tighten them to be snug with a quarter inch drive.
you need a special wrench you can get on eBay to hold the fan blade still.
If The car has a lot of miles on it I would just get a new viscous clutch while you’re at it
well I’ve rambled on enough;-)
Discussion Starter #12
thanks for the concern.
just got the fan all installed and thught i was gong to get the smog certifivcate but they found more things wrong haha specifically the fan shroud which i didnt know i needed and a new oil dipstick tube.... order both but im wondering what bolts or screws i will need to attach the fan shroud... also does the oiltube just have the one bolt and the just comes right out? ill see if i can find a tutorial but the attachment is key
Who the hell are you taking the car to? Is it an actual smog test facility, or a BAR referee?
NONE of my smog techs that I've taken the car to ever given me any issues.
I once took my car to the smog tech like this. No seat belt, airbag light on, all kinds of warning lights on the dash except CEL. Tech looked at me funny but didn't find any issues regarding the emissions. This is the year where they insert the sniffer into the exhaust and dyno, and he did that. No issues at all.
My 98 E300 in my sig also has no engine fan at all. Passed with no issue too.
I've seen rolling shells -- and I do mean rolling shells, meaning only thing actually attached to the shell was the engine, transmission and gas tank. No doors, no panels, no interior, nothing. The car was towed to the smog test. Smog tech drove it up the ramp, plugged it in OBD (because it's after 2000 MY) and because all the emission monitor cycles were done, and the cluster was installed, showing that CEL worked and it was currently off with engine running, it passed.
Mind you, car had no radiator either.
So I don't know who the hell you're taking the car to.
Discussion Starter #14
Its an automotive shop, but i think the tech i got was new and didnt want to ok it and failed it under the official title of "tampered". I guess i wouldnt have even know i needed the shroud but it makes sense with that fan exposed now. oh well just have to wait a little longer till the parts are delivered to have tags.
...............say what now?
Go find a test only station. Not a smog test and repair, it's in their interest to jerk you around.
Discussion Starter #16
I need to know how is the fan shroud mounted? ill try searching but not sure what it would look like, some sort of bolt and nut?
Dallas, Texas
1 - 17 of 17 Posts
