Engine is an M110.990. Finally, the car runs. The fuel pump, accumulator, filter, lines are new and tank restored. Spark plugs and air filter also new. Made sure the new spark plugs did not have an integrated resistor, since the wires already do. Once clean fuel was flushed through lines up to distributor, the car started after sitting 10-15 years. Distributor and injectors have not been replaced.
If I start the car cold, it will idle nicely. Once taking it for a drive and it warms up, when coming to a stop or very low speeds, the engine stalls. For context I did some testing while stationary. I started the car from cold and it idled fine (about 800 rpm) until it warmed up, then the idle dropped to about 550 rpm once warm and in park. When putting the car in drive and not applying throttle, the idle drops momentarily to around 300 rpm, recovers slightly, then stalls. I shut off the car and adjusted the mixture screw (3mm allen) 2 times, each in increments of 90 degrees clockwise to go richer. This did not solve the problem, and may have made it worse. Any thoughts on where to go from here are appreciated.
This plastic piece connected to the throttle actuators is also starting to deteriorate and chip away slightly. Does anyone have an explanation of this component and its replacement part number?
