Hi there, hope all of you are well.
Lurked this forum for a while and since purchasing a 04 Mercedes C220 CDI and having some issues I thought there's no place better to go for some info.
My first question/issue is...The Engine cuts out randomly, the recovery guy showed up and connected his diagnostic device and said something is going on the emissions system (something of that nature) he couldn't pin point it exactly?
The cars done around 150,000 miles if this counts for anything.
Second thing..I wanted to get some Adharaz wheels for it, its an Avantgarde SE and was wondering is the suspension already lowered on this model?
Many thanks in advance for your time and replies
Outstanding Contributor Always Remembered RIP
216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
The CPS is a known problem if the car only cuts off when hot and never when cold, they seldom leave a fault code.
You can look at the rev counter when cranking, if it does not move, then the CPS, if it goes to about 200rpm then its not that
