1986 560 SEL
Good day all.
I found a coolant puddle on my driveway a few days ago. After searching for quite some time, I did find a trickle of coolant coming from a "weep hole" on the RH inner fender, beneath the coolant reservoir. I see no hoses leaking.
I know the overflow hose runs from the back of the reservoir into the fender on that side, but have not been able to find where it terminates. I figure that hose ends inside the fender and overflow is supposed to come out of that hole.
There has been no overheating going on, but the reservoir is low. The coolant level sensor in the tank is apparently not working since I've seen no dash light.
Could this be something as simple as a tank cap seal gone bad?
I normally don't live that good, but...
Thanks much.
1991 560 SEC 1994 E500 2014 E350 Cab
Well most likely the bottle is just full. That braided hose that runs from the reservoir into the fender could be toast, cracked and leaking and or just the bottle is full and spilling out. Turn wheel to the right and then remove the (IIRC 10mm screws) from the inner fender wall and have a look. Bottle has two nipples, one with a hose and the other to spill out when full.
2010 glk350 91 560sec 74 230 66 220seb 86 300e 88 300e
replace the cap on the resivior(expansion tank)
