IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
hi guys i dun know why but im contemplating an engine conversion on my 1985 190E 2.3 I wanted to put an190e 2.6 motor in it. i know that i need an engine and a matching transmission. radiator, probably the acessories, wiring harness, computer, mounts, fans, relays. the engine harness comes with the ecu harness and the fuel relay panel thing. would i need to modify the harness to plug into the car or do i need to completely rewire the car inside and out. new fuse panel? does ne one have a list of parts needed for an engine conversion and/or a rough list of steps to do the conversion?
thanks jippi
1989 300CE
Jippi - 5/6/2005 8:48 AM
thanks jippi
Why not just sell the 85 and the money you were going to use for the motor change and buy a 190 2.6 or a 2.3-16?
'85 2.3-16 '99 C280 '11 GLK350
I agree that it would be better to just buy a decent 2.6L
If you do swap, the transmission doesn't need to be changed, nor the fuse box. A new instrument cluster from a 2.6 should be on your list.
Its definately easier to buy a 2.6, an engine swap could cost you up to and around €3000 and the value of the car will decrease naturally as its been tampered with. Its definately easier to buy.
W201, W202, W203, W204, W205 Moderator
Amethyst 2001 C320
It's not worth it to do a swap. Unless, of course, you're putting in a B16A with VTEC...that would be pretty sweet (but would take some serious work).
I just helped my friend put that kit into his 89 Civic 4 door. There's just no end to the power, and last night with 4 people in the car, we owned a Tibron with just the driver in it. [:D]
IR MODERATOR
thanks. it wasnt something i was really taking seriously it was just pure curious because i have a friend whos parents own a salvage yard and he can get me the engine and tranny assembly out of an 87 190e 2.6 for about 200 usd the car has round 90k and i heard the thing run and it runs great. the car was wrecked in rear. so i was thinking of making it a summer project. if i was getting a new benz i would probably consider the sec or sel, the 190e look and drive incredible but they're small inside and i have to hear it from my parents whenever they ride in it. ehh thanks for the feedback. any one know where i can get of used or recovered door panels in the dark red color. and also body side mouldings like the newer 190e's.
thanks jippi
Ive never done a 2.3 to 2.6 conversion but for the 2.3 8v to 16 valve conversion
I just had to change the ecu, and engine to ecu harness to the 16valve stuff, which required me taking apart the ac evap to fit the wires under. and i just used the 8 valve fuse box, and also added the power and heated seats. If you know what your doing and not missing anything it shouldnt take that long. My swap took 2 days, but i didnt add the seat stuff for a while.
