SL60
My car has been garaged since early november. Today I went to start the car, I noticed that the engine "clicks" repeatedly and won't go away. As I revved the engine, the clicks clicked faster. The clicks seems to be emanating from the driver side of the engine. I usually start the car every 2-3 weeks and this is the first time it clicked. Any clues what might be the source for these clicks, and what might be the solution to this problem?
1990 500SL
i'm experiencing the same clicks! altho my SL is my daily driver the clicks seem to go away after i drive it a bit. they are only present after i let the engine sit over nite in the cold do you exhibit the clicking. ne one have ne ideas?
Thanks,
Devon
BenzWorld Elite Member
2004 SL55, 2006 Range Rover Supercharged, 2013 Infiniti M37
"Sounds" like the lifters to me.
As the car sits & the oil drains to the pan
the oil in the lifters slowly drains out.
Typically upon start up the oil pressure will
fill the lifters.
I would suggest checking to make sure there is adequate oil pressure. An oil change would also
be a good starting point.
Brett
Outstanding Contributor
2005 SL600, (2) 2003 SL500
Mercedes issued a Service Bulletin on this ticking problem. You can read about the SB and the fix here: http://pages.prodigy.net/jforgione/MB_lifter.html.
