1 - 9 of 9 Posts
1985 500SEC
Does the 1.8 and 2.6 share the exact same chassis and body? meaning would you be able to fit any engine that would fit in the 2.6 or 16V into the 1.8 engine bay??
1985 500SEC
Discussion Starter #2
Oh also, the 5 speed manual transmission that comes with the 1.8... are there any other engines that bolt on to it?
'98 E300, '10 GL350 Bluetec
The body is the same across all engine sizes used, so you could replace the engine with any of the ones used in W201.
IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
the only main difference between the 2.6 and the 2.3 (4 and 6 cyls) is the 2.6 had a removable rad support which allowed access to the front of the motor.
'85 2.3-16 '99 C280 '11 GLK350
The whole front end of the 2.6L model is different than the four cylinder cars because of the extra length of the engine. The radiator support is removable, not welded like on the 4 cyl, because the front end has to be removed for any work in the front of the engine.
If you're thinking of a swap, remember that more than the engine differs; the cooling system, a/c, wire looms, etc. Again, your most "cost effective" way towards HP is buying a complete 2.6
1985 500SEC
ahhh i see. So its alot more work to swap engines in the 4 cylinder models.. were there any other 4 cylinder or modern engines made by Mercedes that is about the same size as the 1.8 and 2.3? For example the C220 Kompressor or somethin...
Many thanks, you guys are great help.
And to go off topic a bit... The factory black interiors in the 190.. is the roof and carpet also black or are they grey??
190E 2.3 Sportline / 190E 2.0 Auto
Carpet is black, roof lining is grey, mine is as 2.3 Sportline with full leather interior. Black :)
1985 500SEC
is there a difference between the sportline and standard seats? or any difference in the interiors?... Actually what makes a sportline a sportline?? does it have bigger brakes and better suspensions or somethin??
1 - 9 of 9 Posts
